Blind Spot Monitor Taillight - Re-flash needed?
Bpebler
Hey all, I am planning on picking up just the tail light housing tomorrow to swap a broken one from earlier today. The housing I am looking to purchase is OEM and has the spot for the BSM, but not module itself. Mine is still intact and I plan on just swapping it over to the new housing. Is there anything I should be concerned with? Here are some photos of just the housing plus my busted light. Part of my concern is where the blue and white wire go down where I cannot see. I am assuming it is just a plug there as well?
If the used new one does not have the module installed, you will need to swap out the main connector as well. The regular tail light does not have the internal wiring for the module.
