Best oil choice
Hondo 167
Hello everyone
What does everyone recommend for motor oil brand. I own a 2023 Ram 2500 diesel truck. I understand they recommend Rotella T-6 10-30 weight for Southern California areas . Is this good enough oil or should I make the extra expense and buy Amsoil brand ?
TIA
You are in the 1500 gasser forums. But yeah, I would not have a problem running with rotella. Used 15W40 in our work HMMWV.
I would recommend that you post this question in the HD forum. Actually I would recommend that you do a little research on your own instead because this type of question in a forum will give you more answers than you want. I have used Rotella and Amsoil and would recommend either brand.
