Best cargo lights
wallyuwl
Looking for decent cargo lights to go by the 3rd brake light that don't break the bank. Would prefer to avoid Amazon. I have some extra T10 size but think these are T15. And the Canbus in the RAM makes finding ones that work properly more difficult.
What have you used?
Also, if replacing the gasket at the same time with the Home Depot one, how did you install it? Use anything else, like flex seal?
I was thinking of getting a LasFit lighting for the third brake light. But I'm thinking of getting this instead. Click the link in the video description.
I used Lasfit (newer) 921 LEDs for the cargo light (921 912 White LED Bulbs CANBUS Error Free For Reverse Back Up Light
https://www.lasfit.com/products/canbus-921-912-led-reverse-back-up-light-bulb-upgraded-version) and Diode Dynamics for the 3rd Brake Light.
Did not replace the gasket & have not had any problems w/ water seepage or the dreaded Key Fob Error. Good luck!
I've got these Lasfit LED bulbs in my cargo area and my key fob won't work when they're on. Do the newer ones fix this?
The Key Fob error hasn't been a problem w/ the newer Lasfit LEDs and Lasfit typically have been good about exchanging the older LEDs for the newer LEDs. And as noted, while more expensive, the LEDs by DD also work very well and are made in the USA!
I only have DD, but good to know about LF standing behind the product.
Had Lasfit and they gave me issues for the third light with fob. I returned snd bought diode dynamics and have no issues. Few months latef Lasfit supposedly changed their 3rd braks light and have no problems.
Just ordered the LasFit for $25.50 after discount code, and free shipping since over $25.
