Belltech 6-8” lift question(update with Belltech response)
Phil187
Just curious if anyone knows why with Belltechs 6-8” lift kit that it states it won’t work with E torque models?
reply from belltech
Thank you for reaching out to Belltech suspensions with your questions. Our lift was designed off the 5.7 Hemi only and we will not have crossmembers or any components that will work with the E torque engine so that is why we exclude this application
I'm thinking, they never even looked to see the underside is the same or not. If you can check out a regular HEMI and confirm yourself the underside look the same. The engines are the same and the etorque sits at top on front of engine. I think they're probably blowing smoke up your ........ You might be able to even look on MOPAR site if there are different parts, or they match.
They should be. It's just an add on to the engine and wiring for battery. Hit the local dealership and crawl under.
