Bed rail cap removal help
RamRebelSteel
Los Angeles
I tried digging around youtube for a tutorial on removal the plastic bed rail caps on the sides of the bed but had no luck. Anyone have any information?
It's on a 2018 Ram 2500 long bed. I'm sure it's the same procedure as any 4th gen Ram
In two words, push and pry. Feel under the bed rail for the plastic tabs. Push up on each tab as you pull the cap from the top. You might want to use a quality plastic trim removal roll to pry the cap up till you get it started. Be prepared, you'll likely break too many of the tabs to do a secure reinstall.
