Six_Swix
Curious if any of you folks might have a recommendation. I'm look for a bed rack. Not one that hangs off the back or on top of a hard top.
Cheers
Cheers
Cheers
Made one out of 2x4s. It squeezes the tires using carriage bolts and wing nuts. View attachment 55408
Possibly could do a lever of some sort, but honestly you wouldn't need to. I only loosen it slightly when taking the bike out so it's only a few turns to tighten back up.I’ve been tossing ideas around in my head for a diy rack and trying to come up with one that’s secure and easy to use. That looks like a pretty slick set up, especially being able to pinch it down securely. I wonder if I can find some sort of lever to use in place of a wing nut which would allow you to set it for each size bike tire, then merely push down on a lever to cinch it up tight even faster.
