I found a new use for the Bed Divider - I added two fork mounts and now it works great for mounting a couple of bikes in the bed. Very useful as one of my bikes is a long wheelbase recumbent which is otherwise very hard to transport.
Just found another benefit of this configuration. I brought my short wheelbase back from Ohio and its crank sticks out over front fork which would normally hit the cab if I had fork mounts mounted behind cab as is common in pickups. But since they are mounted on the bed divider, I just moved it back. Works great!.
I did the same thing, except with worm drive hose clamps. It's rock steady.
(I was worried about the structure of the divider being too soft to maintain that bolted joint - has your set up worked well over time?)
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
