BDS 4" Non-Air w/ ORP Measurements?
suli
World
Anyone have measurements for the BDS 4" lift on a non-air suspension setup with 35's like @Rockman did for his (since he has the air suspen)? Bonus points if you have the BDS 4" w/ORP (off road package). Looking for tip of fin height to floor for garage clearances.
I've been looking for the same data for the same reason. But I was thinking that I really only need the measurements to the bottom of the wheel wells. Then I can see how much different it is from what I have to start with. I know how much room I have between the shark fin and the garage beam. If I know how much taller they are at the fenders, I can take that out of the room I have on the top to see if it'll fit.
What I've found is that I have more room to play than a simple measurement to the top of the fin would suggest since my driveway is at a slight angle which makes my truck a little bit lower when it goes through the door.
Top of the shark fin on mine is 81-1/2" with the tires at 38psi.
2019 Crew Cab 6'-4" box North Edition (ORG suspension) and BDS 4" lift with 305/65R18 BFG A/T's on 18x9 Fuel Trophy D551's
Mines got the 4” lift on 35s (with a 2” lift in the rear instead of the 3” that comes with BDS) and the bottom center of my front wheel well is 42 3/4” & the rear is 41 7/8”. The space from the top of the tire to the wheel well is 9” up front and 8” in the rear. I’d assume for ORG you’d just add 1” to both of those
