Oldphart
HI Gang,
I've got a 2021 Lonestar 5.7 ETorque with 49k miles on it; purchased 3/21. The battery voltage has always ran between 13.3-13.8 until a month ago. Now it's between 14.0-14.6. It now takes a bit more time to start when cold in the morning. Could the increase in battery voltage from the ETorque battery be due to the battery failing? If another battery is indicated, what do you guys recommend? I've got a Batteries Plus close by that recommends either a Duracell AGM or the X2 AGM.......man, those are pricey but "buy once, cry once".
