Base Speaker Upgrade, Sub Install, Active Noise Cancelling
Changed the 4 6x9's in the doors to Infinity Reference 3 Ways
Dash speakers are now 3.5" Infinity Reference. Had to add resistors to increase ohms and reduce volume.
Single 12" Ported Foxbox under rear seat.
12" Rockford Punch P3
500W Rockford Punch Amp running at 1 ohm (+/-750W per test sheet)
Knukonceptz 4 Guage Kolossus Flex Kit with upgraded RCA's, hardware, etc.
Pulls signal from factory amp under drivers seat. Tapped into the pre-amp signal.
Disconnected active noise cancelling by doing some snipping on the factory amp. No interior drone with the sub running.
Wired a toggle switch under the dash next to the sub gain control to cut power to amp at any time.
6 speakers and a 12" is all you really need. Sounds (y)
I have the HK system we’re did you get the wire color info and are the speakers 4 ohms Off of the factory amp?
Do you have a pic of the sub box? I like the space under the seat so just want to take up half if possible.
