Has anyone installed the reverse Baja lights? I have a painted rear bumper with retractable step and reverse sensors. Where did you attach the bracket?
Anyone have an experience with Baja Design S2 reverse lights? Any reviews on these and install advice is appreciated! https://www.bajadesigns.com/products/Dodge-Ram-Rebel-1500-19-On-Dual-S2-Reverse-Kit.asp The oem reverse light barely put out anything so looking for some light!
That was before Baja had brackets. The directions from Baja for the bracket are not that "picturesque". Best of luck and keep us posted if you do use Baja's brackets.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
