IsaiahSchlagel
- Oct 11, 2024
Hello!
Today I installed a cold air intake and a oil catch can in my 2020 ram 1500 rebel. I disconnected the battery negative terminal before starting. Before this installation, everything was working perfectly. After the installation, the monitor/uconnect system is acting up. There is no longer an app for the backup camera and nothing at all happens on the screen when I put the truck in reverse. Also, the A/C and heat system is acting very strangely as well. I briefly inspected the fuse box and did not see any fuses that appeared to be blown. I attempted to disconnect and reconnect the battery. I attempted to reset the uconnect/monitor. I attempted the unconnect soft reset. Nothing has worked so far. Does anyone have any suggestions?
Thanks in advance!
Thanks in advance!
