B2 Fab Round (aggressive) Muffler & Resonator Delete Kit
Mhorton814
Clearfield, PA
I have just ordered the B2 Fab Round Muffler Delete and the Resonator delete kit with the 5" tips. Ended up $525 out the door which is half the cost of the S-Type I was originally going to get. I was wondering if I could tackle the install and how advanced it is. I do not have much experience with any work on vehicles and I do not have a lift. I did manage to install my S&B CAI so I'm not completely helpless. Or should I just take it to a local muffler shop. Just looking for some advice. Those of you that have this set-up or something close, how do you like it?
It’s pretty easy, one cut behind the muffler and one cut on each resonator. It took me a couple hours at the most lying on the ground no lift, but my truck had a 6” lift. I went with the moderate and it sounds great. My only complaint is the black tips got a replacement set on Monday and by Tuesday afternoon the paint or powder coat was already peeling off. I’m waiting for a reply from them again I might just ask for a refund and get different tips, been through 2 sets in 7 weeks. I’m sure they will make it right.
I have a lot of ground clearance.
Awesome, thanks for the reply. I think I may try my hand at this. I hope your tip problem works out. From what I heard, Matt from B2 is a pretty good guy to work with when it comes to that stuff. By the way, awesome looking RAM!
Thank you, I’m sure you can handle the install with no problem!
Dang, $525 for all 3 kits! That aint bad at all.
Think I need to get my order in!
Anyone have any issues with leaks on clamp after install? If they leak by the clamp does that create any extra noise?
