j2ttu
- Jul 11, 2022
I recently bought the AuxBeam Switch Panel and a Rough Country DRL Light Bar. The light bar itself came with a 3 position light switch but I would like to hook it up to the Switch Panel. This is where I got a bit confused. The positions on the switch are DRL ON - DRL OFF/LIGHTBAR ON - OFF.
I thought I could use a fuse tap and tap a fuse to have the DRL always on, then wire the other two wires to a position in the Switch Panel. Would I wire those two remaining wires from the switch and the main +/- from the light bar to the same spot on the switch panel?
I have other pod lights coming with DRL as well.
My idea is to have the DRL on when the truck is on and be able to turn the light bar on with a switch.
Attached the wiring diagram from RC.
Any help would be appreciated.
