On top of the main fuse boxPut mine on top of the fuse box too. Used jb weld high temp plastic. No issues, easy access.
Do you have a pic?Yes. Couldn’t find a bigger box to house it in, saw others on Tacoma/tundra pages who did the same thing. Been on a little while now with no issues. Jb weld been holding up great, no issues overheating and if fuse box is needed, I have enough line to pop the top off.
Ah ok. So is this just a fuse panel? With negative posts or do they have relays too?Don’t judge haha. My first time wiring. More has been added since. Looking back at it, there were better ways to hide the wires and maybe more efficient but had fun learning blah blah blah.
SameI put mine right on top of the fuse box. Don't have any pics atm. I just left a couple extra inches of cable to be able to remove the lid.
I did the sameI put mine on side right behind headlight area on driver side. Would love to see if someone knows how to mount where the oem location is for the 2500-3500s are. Maybe someone can at minimum create a small bracket where I currently have it to use both of the ground posts and not just 1 that I am currently using otherwise. I’ll grab a pic tomorrow of where mine is
