Auto dim Highbeam doesn't work
gbecker99
2019 Ram 1500 Laramie
My truck has Auto dim Highbeams. I've verified that the setting is turned on in settings. About a year ago this feature stopped working. What else should I check. Thank you.
Do you get the message about auto-high beams enabled in the EVIC when you turn on your lights?
I noticed that the headlight rotary switch didn't change modes when I rotated it. So I popped off the switch cover and noticed that wire connector was secure but the black plastic backing of the switch component wasn't securely attached. I pushed to secure it. Now my rotary dial changes modes and I have my auto dim headlights working. Thanks for your suggestions.
