randmckikas
- Nov 20, 2024
I am in the middle of installing a subwoofer and wanted to share how I got my audio outputs to send to the amp. Disclaimer: I am not an audio expert.
My issue was the head didnt have any audio outputs I could tap into, all went through the fancy harness system (working on a 2025 warlock). So I took apart one of the rear doors and began tracing wires up to somewhere easy to tap. I dont know who at Ram designed the electrical connection between the door and the frame but they made my life so much easier.
I've attached some pictures to show what Im trying to say but essentially the rubber pass through from the door to the frame has a connector for the door side, a connector for the frame side, and a coupler in between the two, this made tapping into the audio signals from the frame side a simple course of cutting the wires and adding some spade connectors to run an addition pair of wires to the amp.
