Are the readylift UCAs the same between the 2" level and the 3.5"?
VaBeachRam
So I think I'm going to basically do the 3.5" lift from readylift but use Bilstein 5100s instead of the preload spacers. They make a kit that just has the 2" tophat spacer and UCAs but I'm wondering if the control arms between the two kits are the same? Also does anybody know if you can order the rear lift from them separate as well? It's not listed on their site.
the preload spacers are the ones above or above the strut house, i have the readylift i just transfered from a 19 laramie to a 20 laramie off road, the mpg is bad, think ill take the spacer in back off and adjust front accordingly
So I just got off the phone with them, they are the same UCAs but unfortunately they won't sell me the 3.5" kit without the preload spacers and I can't order the 2" level kit and add the rear spacers with it, they will only sell the rear spacers with the 3.5" kit. Looks like I would either have to eat the cost of the spacers, try to sell them to someone else (though I doubt I could get close to the $200 they retail for), or do the 2" level kit and find another company that sells a rear lift.
how much are the rear spacers, i might sell mine dont like it with the orp shocks
what is the bump stock thought it was just a spacer
The other part of the rear that attaches to the frame to keep the axle from slamming into it. If you look at the SST kit it's the square blocks I believe, it should go between the frame and the factory bump stops which are usually rubber and cone shaped. Not sure what they look like on these trucks.
what is the difference in removing the front spacer above the spring vs the one on top of the housing?
