Anyone use a 3 in strut top spacer on 2020 ram rebel?
Kgray1112
I’m trying to find out if anyone used a 3 inch spacer on the newer rebels? I bought the ready lift kit but since I have the off-road package I can’t use the preload spacer so I’m trying to get the lift another way.
The reason you can't use the preload spacer is because it will make your cv angle too sever so youll bind and break the axle. If you use a 3 inch spacer the same thing will happen.
