riotpolice
- Oct 25, 2021
Little back story.. I have a 22 limited with the ecodiesel, have had many many issues with the radio and all it does/doesn't do. The first thing that started was on a road trip the truck started charging north of 20vdc after an OTA update while driving on interstate. When we arrived the battery was very swollen and replaced by a dealer where we were. Messed around and had to flash radio backwards to be able to get back home. Many updates later and many trips to dealers local, I am now faced with a radio that barely works, locks up constantly, etc.. a collision avoid issue where the truck sees something not there and activates brakes, a/c that doesn't blow out the correct areas, and on and on.. The last trip to the dealer they decided to flash the ecm/tcm for a shuddering problem that came up and now the truck won't start at times. If the radio acts up, it will continue to run, but if you kill the engine its a waiting game or resetting radio till it comes alive. Along with the newest is the above code that is now active with no check engine light.. any ideas? thoughts?
