Anyone know best way to depin this connector
wackem1
Havin a hard time depinning this connector on 25 ram, trying to to install steps a cannot extract two wires! Any advice appreciated
Those will definitely make it easy, but it can be done with a dental pick. I had to do exactly this on my '25.
or a small paperclip. Slide it in, in the hole above ping to release the lock and gently tug on wire to pull pin out.
I’d be really careful poking improper “tools” into an automotive connector. You mess up one of those pins and you may be chasing electrical demons for a long time. Not telling you what to do, just saying.
Try the long one and push the wire forward since pulling it out did not work. It may be a push through style after looking at it. Its been a while for me. if neither work take a close up picture of the backside of the connector with the wires there may be a "cleaner" to push the lock and remove.
You should be using a small paerclip.
