Anyone have the Retrax EQ tonneau cover and do you like it?
flying53brian
Thinking about buying one for my 2020 Ram Rebel but have dirt bikes and they say it takes up about 12" of the bed, that won't matter to me because the tailgate will be down but need to know if they'll damage the canister if front wheels are pushed up against it?
Thanks for any info and Happy Holidays fellow Ram owners!
Short answer ...no the tires won't damage anything. I had the Retrax Pro (or Pro...w/e its called). Hated it. Mainly because the box blocked access to the lower tie down points in the bed near the cab. Its not as bad if you dont have a drop-in bed liner, but with a drop in...its a nightmare to get to them.
I have a ProMX, the box is pretty durable. I would think the only damage would be to the coating. Like scratching it I’m referring to. I have a RamBox and the only negative factor to consider is the track reduces the overall usual space. You can slide a 4X8 sheet of drywall/plywood in, but if you wanted to slide a 4’ wide box into the bed, it can’t be higher than the bed side. It will not fit due to interference with the mounting rails.
I don’t know about EQ cover, but I’ll say the MX Pro is aluminum and I can walk on it. Handy for cleaning the roof. Just saying.
