Anyone go from 3.21 to 3.92
jthorn75
I have a 2wd, I was curious if anyone has made the change in the rear end and if anyone happens to know the part numbers, would probably be a good idea to add limited slip diff while im in there.
Moes-performance.com. Matt is awesome and will get you all set up. Give him a call and he will make sure you get everything you need.
What is your reason for doing this?
looking to go up to run 35s so i wanted to make it a little easier on the truck, plus its an option i wanted, but had to decide between a truck with a moonroof or gears... you can add gears later but cant add a moonroof...
I just installed 35-12.50-20 on my 19 BIGHORN with 3:21 gears and don’t really see a difference, still power to spare
