Any gap between purchase incentives?
Eltaco
This isn’t something I’ve tracked closely in the past. Current Ram incentives expire 3/3. Not sure if that means they’re valid through the day, or up until the day… either way, does anyone know if the new incentives will start 3/4, or if there is a few days gap between these?
In the days before Covid, once a manufacturer started incentives, they would say they could end them at the end of each month only to renew them the next. They would typically run them until the next model year production started hitting the show room floors.
I started looking in January and same to the end of the month not being ready to pull the trigger. I just assume they would be reinstated, which they were, as inventories were still high. There have been some stories beginning to drop. But keep in mind the incentives are very granular based on trim. Like Rebel Trims are getting the same push I assume because that level is selling better. If I gave an educated guess, I bet the incentives are in place until June. But things just aren't the same as past history would point.
Thank you. Have you noticed if there are any gap between incentive dates?
For example, if current incentives end 3/3, will the next incentives start right away on 3/4?
I’m really not anticipating any major movement. Just curious if they’ll go away for a few days before the new ones arrive.
Often it can take a few business days before they get the next months incentives in place. But they didn't seem to miss a beat from Jan to Feb.
