Any alignment techs? Camber bolt orientation
msnyder1112
Massillon, Ohio
I did some front end work on my truck and after assembling everything, I noticed some pictures showing the camber bolts both oriented the same way. For example;
Head=====Nut Head=====Nut
However, mine were installed (see photo)
Head=====Nut Nut=====Head
Left side being the front of the vehicle.
I installed them in this same exact orientation.
Attached a picture when I had the knuckle and axle. You can clearly see the front bolt, but if you zoom in you can see the nut on the inside.
Is this normal? I don’t know how it came from factory, but the reputable shop that did my life obviously installed them this way.
