Another Wheel & Offset Question
BMRAMAU
Another Wheel Question for DT Limited - Sorry in advance. Just want to confirm if anyone has 18x9 wheels with -12 offset but running a 295/70/18 tyre and if that tyre protrudes past a Limited Flairs. I know a 35x12.5x18 does but being 295/70/18 is it within the flair? Just trying to not throw rocks down the side of the car when on dirt and dont want to add flairs.
Looking at Method NV's with Maxxiss At811 Tyres
Check out Custom Wheel Offset website …. Plug in your numbers in the Gallery Search
The 35x12.5 you mentioned will only stick out 1/2" further than the 295's when mounted on the same rim if that helps. I'm not sure how far the 35's stick out with those wheels so I can't say for sure, but this should give you an idea anyway.
