dale661
I have a 2021 Laramie 4x4 with the Off Road Group Package. It has the 1" lift all the way around. I don't have the air suspension. The wheels are 20x9. The stock tires are the Falken Wildpeak AT3WA's in a 275/55r20. There isn't much space between the tire wall and UCA. From my "guestimates", there is about 19 mm.
Falken has the stock tire listed on its website as being 11.3" wide on an 8.5" wheel, so I'm guessing it's probably a touch wider being mounted on a 20x9.
The main tire I'm wanting to run is a Toyo RT in a 285/60r20. That's what I ran on my 2017. I'm just wondering if I might have any problems. Some people have told me I could run 35'x11.5's, but I don't want to go that big. I just want it a little bigger than what it is right now.
Also, what are you guys using to recalibrate the speedometer? Is the Hypertech one still working with the newer ones or is it better to go with something else?
Thanks in advance, and I look forward to hearing back from any of you with some knowledge!
