Another leaker
Kris4647
I have a 2019 Ram Limited. I’ve had a few weird problems, power steering failure 🤬and an electrical part near the battery lots of big screen wtf incidents.
Yesterday I drove through some really bad rain, as bad as I’ve ever driven through and it started to get water dripping out the microphone above my head. Never had any issues like this.
What are the chances of it being a drain rather than a direct leak from the moonroof?
Definitely seen a few like this on here and elsewhere online.
Thanks for your time
in other vehicles I ve owned with moonroofs I would occasionally side roof open and pour a cup if water in each corner or area of drains and look under car to see if it flows right out. Then you can see if it s a problem and also it will make sure the drains and channel is kept clear. I d guess and say it s your rear upper light or even the antenna.
I wouldn't guess that. While driving, the water will flow to the back of the truck so starting at the antenna or brake light, already at the rear, should flow backwards, not forwards.
Definitely check the roof drains. I've also heard some say that the windshield seal has let water in, but I would think that would also whistle when driving due to air flow.
