ANC Bypass
treefrog
I recently started having trouble with droning noise from the ANC on my 5th gen 2019 1500 with the standard audio system. I ordered two different bypass harnesses that are pictured and both say that they are compatible with my truck. The maestro seems to completely bypass the ANC module, while the PAC brand harness plugs in to the module. Is there a reason for two different designs for the same thing? Is one better than the other? The PAC was delivered first and I installed and it seems to work how it should, the maestro just came today and I am wondering if I should stick with the PAC or swap it out? ThanksIMG_4443.pngIMG_4441.png
I had the Maestro on my previous Ram w/base audio, and it worked fine. I have the PAC style on my current Ram, but I also have the HK sound system, I don't believe the Maestro would work on this one.
