Amp Research Running Boards
dsteece
I bought a 2026 Ram 1500 Rebel Hurricane. I'm trying to hook up the running boards I took off my 2021 Ram 1500. The 26 does not have the green control board in it to plug into. Has anyone found a solution? Thanks
You need to contact AMP. The canbus is completely different on the 2025+. Unless AMP has a solution, you are out of luck.
