Alpharex pro
ttran018
I have headlights from alpharex pro on a ‘21 Ram 1500. Recently I noticed the outer led DRL isn’t on and not activated when I lock or unlock the truck. But if I turn the dial from auto to the ON position, it works. I have the DRL hardness connected to the fuse box F60. So not sure what went wrong..
Check your DRL settings in your radio. There is a DRL checkbox under headlight settings that you can select/deselect. I remember doing that for my VLAND LED lights to resolve a similar issue. Hopefully it works in your situation.
