Alpharex DRLs and AlfaOBD settings
2019rams
I recently installed Alpharex Luxx LED headlights in my 2019 Ram 1500 that had factory halogens. They worked fine for a few weeks until the turn signals started going out and then the DRLs stopped coming on I used AlfaOBD to change the settings for headlights to LED so now I don't get turn signal issues. However the DRLs are still not coming on. At first I thought it was the wiring harness or fuse but when I remote start my truck they come on, but once I get in and press the button to fully turn it on and go into drive the shut off. The startup sequence isn't working on unlock either.
Any idea what to do here or what AlfaOBD setting to change for the DRLs? They currently wired to the battery and plugged into fuse box.
Thanks
