MDS is part of the powertrain control module, and that is generally off limits for changes via obd2 in our trucks. there's a whole PCM unlock requirement for engine performance tuning and thats the area I would expect etorque/MDS functions to fall into.
It's actually easy to do while driving. Just punch the "Gear limit" buttons on the bottom right of the wheel. Keep pushing until you are in "8", but not "D8"
This limits the highest gear you can select. Putting it in "8" leaves all the automatic shifting as normal, but locks out MDS.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
