alphaOBD help
cj7
MD
Couple questions on using alphaOBD on a 20 Laramie:
- is there a setting to enable an Active Air Dam?
- is there a way to enable the off-road screens?
- is there a way to enable the NAV keyboard while in motion (and not screw anything else up)?
- is there a way to raise the speed at which the Surround Cameras are not available?
thx in advance!
Interested in alpha obd changes that can be made.
Sent from my SM-G998U using Tapatalk
No on all that.
Edit: on the first one, if you are adding it and need to enable it in the BCM, then yes, you can. But, you can't control it "on the fly".
No on all that.
Thx. Yes I am adding it, and want it to work in the usual way. What setting is it?
Here is the 'master' thread for AlfaOBD in this forum:
For some reason everyone thinks it is AlphaOBD. :unsure:
Not everyone, but I'm a spelling Nazi. 😉
