AlphaOBD for Windows connection to 2020 Bighorn
TripleB
I have reviewed some of the AlphaOBD posts but I am uncertain how to connect to my 2020 Bighorn let alone make changes.
I down loaded AlphaOBD for Widows to my laptop
My aim is to use the AlphaOBD software to edit my BCM High Beam Light from halogen light to LED light so that I can run daylight running lights when i install a LED
But I am not really conceiving what is needed to connect the laptop to the truck using the AlphaOBD for Windows vs Android etc
1. Buy the OBDLink EX
2. Buy a SGW bypass module? Which one?
3. Remove he SGW module and connect the SGW bypass? There is more than one place to connect the SGW bipass? Where do I connect the SGW bypass?
4. Connect the OBDLink EX to the OBD 2 under the steering wheel? or some other connection?
Thank you.
Post it in AlphaOBD thread, you will receive the answer faster.
Also I could say, i use cheap SGW bypass, it connected to SGW module located under OBD harness. It stays there all the time, I don’t disconnect it.
Link to post in AlphaOBD thread:
