jonnyrebel88
So I have a 2019 Rebel and was using Alpha OBD software via my laptop with windows software, an ECRI security bypass, and an OBDLink EX adapter. Today I tried to adjust my tire size to 295/70r18 which comes out to 2733mm in the input of changing the tire size. I entered all the information as per another thread on here in the Change tire size, car configure tire size, and then also did the ABS configuration as well. Now I have an issue with the parking sensors not working front or rear. I have tried to redo it 3 times going as low as 2644mm which is supposed to be the stock size, but still no luck. Any help would be greatly appreciated.
