Alpha obd help
Akerwin10
Michigan
I tried searching though the treads already with no luck... So I tried using alpha obd for the first time today and no matter which control unit I select it says it cant connect. Am I doing something wrong?
You need to install a Security Bypass Module.
you can get them from Amazon for $25.
I had one already. I figured it out though.. kept accidentally choosing the ios Bluetooth connection instead of android. Thanks though.
