Alpha OBD and SGW question
ljinnc
I have a 2019 Ram DT body built in 10-18, I have searched for the security gateway module and I can't find it. Is it possible that my early build 2019 could NOT have a SGW? If it's got it its not near the OBD plug and it's not behind the radio. Any ideas?
I have a 2019 Ram DT body built in 10-18, I have searched for the security gateway module and I can't find it. Is it possible that my early build 2019 could NOT have a SGW? If it's got it its not near the OBD plug and it's not behind the radio. Any ideas?EFB41CE5-5459-4410-8DAB-372EF733C710.jpegIt right under the steering wheel. It’s hard to see. It’s just above the cable for the emergency brake release.
Does anyone know if alpha obd will let you make program change so I can install the 12 inch screen
