I recently replaced my cluster from the 3.5 inch to the 7 inch premium cluster. But I can't get alfaobd to program engine hours. Is this a common problem?
I remember a post, I think it was on the AlfaObd web page somewhere..
Best results at changing EVIC cluster idle and run hours was best performed with a cabled OBD2 adapter. The issue may be the latency of a wireless link over that of a hard wired connection. Obdlink makes two cabled adapters, the EX, and SX, I don't remember which variant has been used successfully.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
