2020 Rebel
- Aug 1, 2020
Anyone seen or used this rear air bag coil spring replacement kit by Airbag Man? OA6044 - Full Air Suspension Kit
here's a independent video of the Airbag Man kit
The bag that comes in the Airbag Man kit looks way more heavy duty than what comes in this firestone, OEM style bag, rear coil spring replacement kit : 2WD/4WD Dodge RAM 1500 Air Springs | 2595 Firestone Ride-Rite
The Firestone kit has a footnote stating it will not fit Rebel models. I call BS. Maybe not on a factory air ride Rebel. But what could be the reason it won't work on a factory coiled Rebel?? Because you have to run a few more psi to get a measly more 1" in ride height and you loose a bit of cushyness ??
still really leaning towards the Airbag Man Kit as I plan to carry a Cirrus 620 Truck camper a lot off road and it can go 1" higher than factory Rebel ride height.
All input is greatly appreciated !
