Hi folks. New member, long time browser. Looking for advice on my 2019 Ram 1500 Laramie 5.7 4x4 with the air ride suspension.
I started getting the “suspension cooling” warnings occasionally earlier this summer coming off the highway. Didn’t think too much of it until I got the “service air suspension” warning. I turned off aero mode and didn’t get warning for a while, but eventually started getting them consistently. Truck never squatted, but wouldn’t respond to my requests to adjust height. It occasionally would get stuck in aero or OR1, but I’d come outside the next day and it would be fine.
I eventually get under it, remove the dust cover from the compressor and hit the fitting on it with some soapy water. I saw air leaks on 2 of the lines. I call the guys at Rebuild Master Tech and they tell me that I can use this fitting to replace the leaking one. He said I can just snip off the end, push this on and it will work. RAM 1500 2019-2025 (DT) VOSS Suspension Air Line Hose Connector Brass Fitting
I’m underneath the truck with the replacement Voss fitting from RMT. Unscrew the 2 leaky OEM fittings on the compressor, but it just doesn’t feel right. The Voss is a “push in” type fitting unlike anything I’ve used and I can’t see how it would be airtight, so I thread the stock hardware back in place - no worse for wear.
WELL…the ride height has been stuck LOW ever since. The compressor kicks on and runs but has never returned to normal height. It reads “normal” on the dash, but she’s slammed on the ground. I gave it all weekend to fix itself, but no luck. Frustrated, I drove my low rider to the dealership cause my local mechanic wouldn’t touch it. They quoted me $2100 to replace the leaking air lines ($600 parts/$1500 labor).
Dealer said it’s the fittings I messed with leaking. They don’t sell just replacement fittings for the newer version of the air system like they do for the old ones - gotta replace the whole line. He said it’s not lifting the truck at all now cause the leak is so much worse, which I didn’t see after putting it back together. I’m concerned that there could be another, more significant issue they can’t even see at this point. Valve assembly, compressor itself, etc.
I told the tech that I can buy a whole new conventional suspension from airdelete.com for less than he’s asking to put new lines on. He said if it was him, that’s what he’d do because of all the issues he’s seen with these systems.
Between this, hurricanes and some health issues I’m about to pull my hair out. Any suggestions would be welcomed - thanks in advance.
-Sam
-Sam
