Air suspension firmness
cj7
MD
Does the Air Susp ride a little harder the higher up you set it? (sxcluding entry/exit).
seems to me it does, guessing the higher the setting, the higher the air pressure, and the higher the effective spring rate...?
BTW, I love the air susp...
Yes it's firmer the higher you go. I have air suspension and ORG. My 09 Ram road much better than the 20 with Air Ride. I got the Air Ride to make it easier for my kids to get in and out. One they get older I think I'm going back to coil suspension
The ORG does firm up the air ride a bit. I like the combo, but I come from the 3/4-ton truck world. Hit a big bump (e.g. bad railroad crossing) or carry a lot of payload and the air suspension really shines. But I was impressed with the coils, too; I think they’d be great for cruising unloaded.
2020 Limited - between Aero and Normal I don't see much of a difference. I really haven't used the off-road settings but I expect there would be a bit more firmness.
"Aero" has the best ride, Normal is a notch down. The higher you go the bumpier the ride. I love them all, If i'm alone Ride#1 with do just fine in the neighborhood.
