air ride delete
allord
i own a 2019 ram limited, after 60 miles my air suspension started leaking and im thinking of converting to coil springs suspension instead of fixing it is it possible to do that with my model and is there a way to bypass the “service air suspension immediately” message if ive done that
Airdelete.com makes kits for 4th gens, so I imagine they will be making kits available for 5th gens at some point. It's possible there are kits out there from other companies. Have you done any real searching for this? The 5th gen air suspension hasn't really been riddled with problems like it was on 4th gens, so the demand may not be there yet.
i havent found any kit yet but ive done my research i feel like its do able without needing any kit after comparing both systems but companies who sell coil overs mention that thier systems wont work with air ride equiped ram trucks thats why im hesitant to go ahead and switch to coils i will post pics of both systems
- front air suspension
- rear air suspension
-rear coil suspension
im dont know if getting oem rear coils with gox shocks and fox 1500 ram DT coil-over would work
D67E7A50-3587-4914-B9F6-9E1B5A837FC9.jpeg420DA7DE-CA61-4AEC-9319-20595AC00582.jpeg9CE8A007-FD25-4CC7-A9C6-1523303F1B63.jpeg
As Mikeru82 said, the air suspension system is not known to be very problematic, with some exception in extreme cold climates. Having owned the air suspension and seeing how relatively simple and reliable (mine had 229K miles when I sold it) it is, I'd suggest finding the leak and dealing with it.
Did you managed to replace the air suspension with normal suspension?
