Air Compressor mount under bed?
blacksheep37
I'm looking for a spot under the truck - by the spare tire - to mount a small air compressor for adjustable air springs. This is the HD1000 kit - NOT full air bags
I'm considering screwing the compressor to the underside of the bed, above the spare tire. The provided screws are probably about an inch long and I'm concerned they'll pop up through the bed liner.
Is there enough room to mount here?
I just installed a full system in my truck, but if you have a crew cab with the under floor storage in the rear seat, a compressor and regulator fit nicely in there once you remove the inner tub. That way it's all protected from the elements. You can hear the compressor when it kicks in, but it is not very loud. Won't even notice it if the radio is on. Then I just took silicone and sealed up around all the bolts
