Aftermarket wheels Center Bore 78,1 - 77,8
RAMCIKAS
Hello,
There is plenty of questions regarding aftermarket rims on dodge ram with centre bore 78,1 on a hub 77,8.
My question, has anyone yet fitted their aftermarket rims with a center bore 78,1?
The difference is 0.3mm, no ring are available to be supplied because of small space between the rim and hub.
Any advices or experience faced? Vibrations issues or?
Thanks
Ram uses tapered lug nuts, meaning it is lug centered. No rings needed. “If” you somehow found flat faced lug type rims, .3mm is less than the wheel runout tolerance. Mounted 106mm bore on my last truck, no rings needed with OEM lug nuts.
Someone be along shortly to say the opposite.
