Aftermarket TPMS monitor
Baruffic
I mistakenly thought I had trailer TPMS monitoring in my 2020 RAM 3500. So when I purchased my 5th wheel I had the sensors installed in the trailer tires. I found a thread in here about adding it aftermarket but that is well beyond my technical abilities. So I am wondering if there is an aftermarket monitor that will pair with my factory TPMS sensors? Has anyone encountered one?
Thanks
I’ve been using this one when towing my travel trailer with my Durango. I like it because of the large text and you can get an optional signal repeater in case the signal won’t reach the receiver.
RV Tire Pressure Monitoring... https://www.amazon.com/dp/B08DTTV7BC
GUTA Repeater - TPMS System... https://www.amazon.com/dp/B088NDRMMJ
My Ram has TTPMS, so I won’t be using it once I get the sensors installed in the tires.
I already have the sensors in my tires and was hoping to make use of them with some aftermarket monitor, seems like maybe that doesn't exist.
