Aftermarket Bed Lights Power
Patpenrod
I'm looking to install aftermarket bed lights in my Big horn that didn't come with them from the factory. I'd like to tie into power for the cargo light if possible so I can control them with the cargo light switch, but I don't know how to tap into it without having exposed wires, I'd like it to be a clean install. Does anyone know where an easy place to tie into these wires? If I cant do that, I will most likely put a switch inside the bed and tie into the 12v supply to my trailer harness. Does anyone know which wire in the trailer harness is the 12v constant?
I'm open to other suggestions or ideas from anyone why may have done their own install as well. Thanks!
Thank you, for some reason my search was coming up with no results when I typed Bed Lights. :unsure:
