Aftermarket 4 Corner Air Suspension?
Laramie_2019
Can i convert my coil suspension to an air-suspension, either OEM or Aftermarket Options?
My laramie doesn't have that, and i keep hearing everyone rave about the 4Corner Air suspension, and how smooth it is.
There are aftermarket options that you bolt on. Some of the manual inflate versions are fairly cheap but you have to inflate them yourself before you cruise. These are mainly for towing purposes anyway.
If you read some of the threads where folks have driven air and coil suspension concurrently, most report little difference between the two as far as ride goes. As said, air comes into its own during towing.
Ditto to the above. I've had air suspension on a previous Laramie. It was nice and useful when towing but I can't say I feel anything significant between driving a truck with vs. without air suspension. That is the reason I didn't feel like ordering that option on my current Longhorn. After driving this Longhorn for the past 5,000 miles I do not find myself wanting the air suspension in terms of ride quality. This trucks rides incredibly. If I towed all the time and didn't use a anti-sway/wt distribution hitch then the air suspension would be nice. I now also have the option of using a leveling kit or other lift if I so desire in the future. Air suspension does not realistically give you that option unless you want to trick the computer and alter your ride.
