For those that added sound deadening material to the front & rear doors, how did you access the outer door skin? Did you remove the inner door panels or just apply it throught the speaker opening as good as you could? I'm a little leary about removing the inner door panel as it has the window motor attached to it & I don't want to have trouble trying to get it re-installed if there's any kind of linkage attached to it.
