I'm trying to add after market backup light under the bumper on my 2022 Ram 1500 Limited. does anyone know how I can wire them in, where is the best place to tap into the backup light feed?
Ohh i see, i guess i can get rid of my steps since i dont particularly uses it haha They work just fine on all of the 5th Gen Ram 1500s. If you want the step, they work with the Amp Research Step for sure. Let us know if we can answer any questions.
Our reverse light brackets are up for preorder at a discount. These work with any truck that has a rear TRX Tow Hook. The brackets mount to the rear two bolts of the TRX Tow Hook. The light is a Diode Dynamics SSC1 pod light with a red back light and white main light. for best results wire the...
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
